Ir para o conteúdo principal
Dell Inspiron 11z-1121 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 11z-1121 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 11z-1121 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Dell Inspiron 11z-1121 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 11z-1121 Keyboard Replacement: passo 3, imagem 2 %32
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 11z-1121 Keyboard Replacement: passo 4, imagem 2 %32
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-5, Nance Fall 2016 Membro de USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,521
