Ir para o conteúdo principal
Dell Inspiron 1100 Keyboard Replacement
O que você precisa
    1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Dell Inspiron 1100 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
      • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
      • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
      • This step does require some force. Be careful to not bend or break the plastic face plate.
      Pergunte ao FixBot
      Comentar
    2. Dell Inspiron 1100 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 1100 Keyboard Replacement: passo 2, imagem 2 %32
      • Remove the four 3mm Phillips #0 screws securing the keyboard.
      Pergunte ao FixBot
      Comentar
    3. Dell Inspiron 1100 Keyboard Replacement: passo 3, imagem 1 %32
      • Lift up the keyboard to expose the ribbon header on the motherboard.
      • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
      Pergunte ao FixBot
      Comentar
    4. Dell Inspiron 1100 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 1100 Keyboard Replacement: passo 4, imagem 2 %32
      • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
      • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 743
