Ir para o conteúdo principal
Dell Dimension 4600 Video Card Replacement
O que você precisa
    1. Dell Dimension 4600 Video Card Replacement, Side Panel: passo 1, imagem 1 %32
      • Locate the case cover latch on the back of the computer.
      Pergunte ao FixBot
      Comentar
    2. Dell Dimension 4600 Video Card Replacement: passo 2, imagem 1 %32
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Pergunte ao FixBot
      Comentar
    3. Dell Dimension 4600 Video Card Replacement: passo 3, imagem 1 %32
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Pergunte ao FixBot
      Comentar
    1. Dell Dimension 4600 Video Card Replacement, Video Card: passo 4, imagem 1 %32
      • Lay the computer flat so that you are looking down on all of the components.
      Pergunte ao FixBot
      Comentar
    2. Dell Dimension 4600 Video Card Replacement: passo 5, imagem 1 %32
      • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
      Pergunte ao FixBot
      Comentar
    3. Dell Dimension 4600 Video Card Replacement: passo 6, imagem 1 %32
      • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
      Pergunte ao FixBot
      Comentar
    4. Dell Dimension 4600 Video Card Replacement: passo 7, imagem 1 %32
      • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
      Pergunte ao FixBot
      Comentar
    5. Dell Dimension 4600 Video Card Replacement: passo 8, imagem 1 %32
      • Pull the remainder of the card up and out of it's slot.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Arvind
Membro desde: 10/12/11
395 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-10, Regan Fall 2011 Membro de Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membros
Autoria de 11 guias
2Comentários do guia
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
Don't hurt the chickens - Responder Compartilhar
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
William Morgan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 8,165
