Ir para o conteúdo principal
Dell Dimension 4600 Sound Card Replacement
O que você precisa
    1. Dell Dimension 4600 Sound Card Replacement, Side Panel: passo 1, imagem 1 %32
      • Locate the case cover latch on the back of the computer.
      Pergunte ao FixBot
      Comentar
    2. Dell Dimension 4600 Sound Card Replacement: passo 2, imagem 1 %32
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Pergunte ao FixBot
      Comentar
    3. Dell Dimension 4600 Sound Card Replacement: passo 3, imagem 1 %32
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Pergunte ao FixBot
      Comentar
    1. Dell Dimension 4600 Sound Card Replacement, Sound Card: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      • Lay the computer flat on its side so that you are looking down on all of the components.
      • Very important at this point you connect your antistatic wrist strap to the chassis because the computer is no longer connected to ground at the power source. There is potential for static discharge which could destroy components.
      Pergunte ao FixBot
      Comentar
    2. Dell Dimension 4600 Sound Card Replacement: passo 5, imagem 1 %32
      • Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
      Pergunte ao FixBot
      Comentar
    3. Dell Dimension 4600 Sound Card Replacement: passo 6, imagem 1 %32
      • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
      Pergunte ao FixBot
      Comentar
    4. Dell Dimension 4600 Sound Card Replacement: passo 7, imagem 1 %32 Dell Dimension 4600 Sound Card Replacement: passo 7, imagem 2 %32 Dell Dimension 4600 Sound Card Replacement: passo 7, imagem 3 %32
      • Locate and remove the white connector on the sound card by pulling on the black cable.
      Pergunte ao FixBot
      Comentar
    5. Dell Dimension 4600 Sound Card Replacement: passo 8, imagem 1 %32 Dell Dimension 4600 Sound Card Replacement: passo 8, imagem 2 %32
      • Grasp the Sound Card and pull it up and out of it's slot.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Arvind
Membro desde: 10/12/11
395 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-10, Regan Fall 2011 Membro de Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 21
Ao todo: 5,745
