O que você precisa
Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
While i switch on computer not start. Does it have fuse inside? Shall i check it first?
Remove the bracket-securing screw, and then remove the drive bracket from the computer.
Remove the hard drive-securing screw, and then remove the hard drive from the bracket.
Install the new hard drive in the bracket. Place the hard drive in the bracket so that the two screw-hole tabs insert into the two screw holes on the hard drive, and then secure the drive to the bracket with the screw that you removed.
7 outras pessoas executaram este guia.
2 comentários
Some pictures would be nice.
No power arrived while i switch on the button of compiutor
