Introdução
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
The system board, also known as the motherboard, is the backbone of the computer; it allows all major components of your computer hardware to communicate with each other. If you are experiences a glitching display, unresponsive peripherals and sluggish performance, try the Dell Chromebook 5190 troubleshooting page for possible solutions before replacing the system board. If you are still experiencing these issues after troubleshooting, you may need a system board replacement.
Please make sure your laptop is off before beginning, and remove all cables or devices populating your laptop ports.
O que você precisa
To disconnect the first purple I/O cable, first lift the purple tab upwards.
Next, pull the purple tab away from the motherboard.
