Introdução
This guide will aid you in replacing your Dell Chromebook 5190 I/O board.
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
The I/O board on your laptop helps physically connect external devices to your computer. If you are having issues with your computer identifying external devices when connected, try the Dell Chromebook 5190 troubleshooting page for possible solutions before replacing the I/O. If you are still experiencing these issues after troubleshooting, you may need a I/O board replacement.
Please make sure your laptop is off before beginning, and remove all cables or devices populating your laptop ports.
O que você precisa
Disconnect the first purple I/O cable by lifting upwards and pulling away from the I/O connector.
