Ir para o conteúdo principal
Dell Chromebook 5190 Battery Replacement
O que você precisa
  1. Dell Chromebook 5190 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Battery Replacement: passo 2, imagem 1 %32 Dell Chromebook 5190 Battery Replacement: passo 2, imagem 2 %32 Dell Chromebook 5190 Battery Replacement: passo 2, imagem 3 %32
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Battery Replacement: passo 3, imagem 1 %32 Dell Chromebook 5190 Battery Replacement: passo 3, imagem 2 %32
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Battery Replacement: passo 4, imagem 1 %32 Dell Chromebook 5190 Battery Replacement: passo 4, imagem 2 %32
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Battery Replacement: passo 5, imagem 1 %32 Dell Chromebook 5190 Battery Replacement: passo 5, imagem 2 %32
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Battery Replacement: passo 6, imagem 1 %32 Dell Chromebook 5190 Battery Replacement: passo 6, imagem 2 %32 Dell Chromebook 5190 Battery Replacement: passo 6, imagem 3 %32
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
Conclusão
Denise Cano
Membro desde: 02/10/22
617 Reputação
Autoria de 4 guias
Equipe
Gateway, Team 1-3, Pee Spring 2022 Membro de Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 522
