Introdução
Having trouble with broken or stick keys on your keyboard? This guide will provide you simple step-by-step instructions on replacing your keyboard for the Chromebook 13-7310.
O que você precisa
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
3 outras pessoas executaram este guia.
1Comentário do guia
I’ve never pulled apart a computer before, and this guide was perfect! thanks
