Ir para o conteúdo principal
Dell Alienware 15 Memory Module Replacement
O que você precisa
    • After turning the computer off, close the display and turn the computer over.
    Pergunte ao FixBot
    Comentar
  1. Dell Alienware 15 Memory Module Replacement, Remove the Back Panel Screws and Lift: passo 2, imagem 1 %32
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
    Pergunte ao FixBot
    Comentar
  2. Dell Alienware 15 Memory Module Replacement, Optional: Disconnect the Battery: passo 3, imagem 1 %32
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
    Pergunte ao FixBot
    Comentar
  3. Dell Alienware 15 Memory Module Replacement, Memory Securing Clips: passo 4, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
    Pergunte ao FixBot
    Comentar
  4. Dell Alienware 15 Memory Module Replacement, Remove Memory Module: passo 5, imagem 1 %32
    • Slide and remove the memory module from any memory-module slots that you would like to repopulate.
    Pergunte ao FixBot
    Comentar
  5. Dell Alienware 15 Memory Module Replacement, Adding New Memory Module: passo 6, imagem 1 %32
    • Align the notch on the New memory module with the tab on the memory- module slot.
    Pergunte ao FixBot
    Comentar
  6. Dell Alienware 15 Memory Module Replacement, Firmly Press the Memory Module Down.: passo 7, imagem 1 %32
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place. Do this individually for each memory module that is replaced.
    • NOTE : If you do not hear the click, remove the memory module and reinstall it.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, screw the base panel on again.
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 971
