Ir para o conteúdo principal
Dell AC511 Volume Knob Replacement
O que você precisa
  1. Dell AC511 Volume Knob Replacement, Front Panel: passo 1, imagem 1 %32 Dell AC511 Volume Knob Replacement, Front Panel: passo 1, imagem 2 %32 Dell AC511 Volume Knob Replacement, Front Panel: passo 1, imagem 3 %32
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
    Pergunte ao FixBot
    Comentar
  2. Dell AC511 Volume Knob Replacement: passo 2, imagem 1 %32 Dell AC511 Volume Knob Replacement: passo 2, imagem 2 %32
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Dell AC511 Volume Knob Replacement: passo 3, imagem 1 %32 Dell AC511 Volume Knob Replacement: passo 3, imagem 2 %32
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
    Pergunte ao FixBot
    Comentar
  4. Dell AC511 Volume Knob Replacement, Volume Knob: passo 4, imagem 1 %32
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
    Pergunte ao FixBot
    Comentar
  5. Dell AC511 Volume Knob Replacement: passo 5, imagem 1 %32
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
    Pergunte ao FixBot
    Comentar
Conclusão
William Cook
Membro desde: 03/19/24
653 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 30
Ao todo: 364
