Ir para o conteúdo principal
DeWalt DWE4011 Power Cable Replacement
O que você precisa
  1. DeWalt DWE4011 Power Cable Replacement, Power Cord: passo 1, imagem 1 %32
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
    Pergunte ao FixBot
    Comentar
  2. DeWalt DWE4011 Power Cable Replacement: passo 2, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 2, imagem 2 %32
    • Remove bottom casing by separating the end handle away from the main casing.
    Pergunte ao FixBot
    Comentar
  3. DeWalt DWE4011 Power Cable Replacement: passo 3, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 3, imagem 2 %32
    • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
    Pergunte ao FixBot
    Comentar
  4. DeWalt DWE4011 Power Cable Replacement: passo 4, imagem 1 %32
    • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
    Pergunte ao FixBot
    Comentar
  5. DeWalt DWE4011 Power Cable Replacement: passo 5, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 5, imagem 2 %32
    • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
    Pergunte ao FixBot
    Comentar
  6. DeWalt DWE4011 Power Cable Replacement: passo 6, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 6, imagem 2 %32
    • Locate the terminals with the two white cables attached and disconnect both.
    • These cables are connected to the outer terminals; connect as such during reassembly.
    Pergunte ao FixBot
    Comentar
  7. DeWalt DWE4011 Power Cable Replacement: passo 7, imagem 1 %32 DeWalt DWE4011 Power Cable Replacement: passo 7, imagem 2 %32
    • Remove the entirety of the cable housing from the device casing.
    • The two wires coming from the power cable should still be connected to electrical housing at this point.
    Pergunte ao FixBot
    Comentar
  8. DeWalt DWE4011 Power Cable Replacement: passo 8, imagem 1 %32
    • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
    • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
1Comentário do guia
Where can I find a replacement power cord?
Ethan Sligar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 79
Ao todo: 4,768
