Ir para o conteúdo principal
DeWalt DWD112 Armature Replacement
O que você precisa
    1. DeWalt DWD112 Armature Replacement, Power Cord: passo 1, imagem 1 %32
      • Remove seven TR20 Torx Security screws from the side of the drill.
      Pergunte ao FixBot
      Comentar
    2. DeWalt DWD112 Armature Replacement: passo 2, imagem 1 %32
      • Remove the top cover to reveal the inside of the drill.
      • Set the top cover of the drill aside.
      Pergunte ao FixBot
      Comentar
    3. DeWalt DWD112 Armature Replacement: passo 3, imagem 1 %32
      • The power cord and the trigger act as a single part and must be replaced together.
      • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
      Pergunte ao FixBot
      Comentar
    4. DeWalt DWD112 Armature Replacement: passo 4, imagem 1 %32
      • Disconnect the second connected wire from the top of the trigger box.
      Pergunte ao FixBot
      Comentar
    5. DeWalt DWD112 Armature Replacement: passo 5, imagem 1 %32
      • Lift the trigger box up to reveal the bottom side.
      • Disconnect the first connected wire from the bottom of the trigger box.
      Pergunte ao FixBot
      Comentar
    6. DeWalt DWD112 Armature Replacement: passo 6, imagem 1 %32
      • Disconnect the last wire from the trigger box using the same method from the previous step.
      Pergunte ao FixBot
      Comentar
    7. DeWalt DWD112 Armature Replacement: passo 7, imagem 1 %32
      • After all four wires are disconnected, the trigger and power cord are separated from the drill.
      • The power cord and trigger can be set aside if further disassembly is required.
      Pergunte ao FixBot
      Comentar
    1. DeWalt DWD112 Armature Replacement, Armature: passo 8, imagem 1 %32
      • Take note of the keyless chuck and the meshing of the gears.
      Pergunte ao FixBot
      Comentar
    2. DeWalt DWD112 Armature Replacement: passo 9, imagem 1 %32 DeWalt DWD112 Armature Replacement: passo 9, imagem 2 %32
      • Grab the metal chuck by the rotating spindle as if you are to tighten in a drill bit.
      • Lift the metal chuck out of its resting place and set aside.
      Pergunte ao FixBot
      Comentar
    3. DeWalt DWD112 Armature Replacement: passo 10, imagem 1 %32 DeWalt DWD112 Armature Replacement: passo 10, imagem 2 %32 DeWalt DWD112 Armature Replacement: passo 10, imagem 3 %32
      • With your left hand, grab hold of the field, which is the large metal block with coils looped around the inside.
      • Use your other hand to take the bearing out from the end of the gear connected to the armature.
      Pergunte ao FixBot
      Comentar
    4. DeWalt DWD112 Armature Replacement: passo 11, imagem 1 %32 DeWalt DWD112 Armature Replacement: passo 11, imagem 2 %32 DeWalt DWD112 Armature Replacement: passo 11, imagem 3 %32
      • Lift the field up once more with one hand and grab the cooling fan with the other hand and gently slide the armature out of the field.
      • The brushes will now be disconnected from the armature, meaning no current can flow from the power cord to the motor.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
1Comentário do guia
Hi I need armature of this drill
kamran ali - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 1,139
