Ir para o conteúdo principal
DeWalt DC970 Motor Replacement
O que você precisa
  1. DeWalt DC970 Motor Replacement, Battery: passo 1, imagem 1 %32
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: passo 2, imagem 1 %32
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: passo 3, imagem 1 %32 DeWalt DC970 Motor Replacement, Drill Assembly: passo 3, imagem 2 %32
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: passo 4, imagem 1 %32
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: passo 5, imagem 1 %32
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: passo 6, imagem 1 %32
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: passo 7, imagem 1 %32
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
Conclusão
Jonathan Hamel
Membro desde: 03/10/16
591 Reputação
4 Guias de autoria
Equipe
3 comentários
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - Responder
Thanks for the heads up on the wires
Daniel Randall - Responder
Is there a fix to replace brushes?
pmac086 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 51
Duração total: 6,043
