Introdução
If you realize your battery charger for your drill is not charging, there may be a blown fuse which can be replaced by following this guide.
O que você precisa
Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
4 outras pessoas executaram este guia.
1Comentário do guia
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
