Ir para o conteúdo principal
Dashcam DOD LS300W Battery Replacement
O que você precisa
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, imagem 1 %32 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, imagem 2 %32 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: passo 1, imagem 3 %32
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: passo 2, imagem 1 %32 Dashcam DOD LS300W Battery Replacement: passo 2, imagem 2 %32
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: passo 3, imagem 1 %32 Dashcam DOD LS300W Battery Replacement: passo 3, imagem 2 %32 Dashcam DOD LS300W Battery Replacement: passo 3, imagem 3 %32
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: passo 4, imagem 1 %32
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Conclusão
Once again, thank you for checking out this guide and I hope it helped!
Pierre
Membro desde: 04/02/13
542 Reputação
Autoria de 3 guias
2 comentários
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Responder
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 6,377
