Ir para o conteúdo principal
DYMO LabelPOINT 100 Cutting Blade Replacement
O que você precisa
  1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, imagem 1 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, imagem 2 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: passo 1, imagem 3 %32
    • Slide the panel release button.
    • Lift the panel.
    Pergunte ao FixBot
    Comentar
  2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: passo 2, imagem 1 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: passo 2, imagem 2 %32
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
    Pergunte ao FixBot
    Comentar
  3. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, imagem 1 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, imagem 2 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: passo 3, imagem 3 %32
    • Use Phillips #00 Screwdriver to disengage cutter from device
    • Remove cutter
    Pergunte ao FixBot
    Comentar
  4. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, imagem 1 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, imagem 2 %32 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: passo 4, imagem 3 %32
    • Use Phillips #00 screw to unscrew blade from blade cutter
    • Carefully remove blade. The blade is sharp and can be dangerous if not handled properly.
    • Replace blade
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Dustin Holifer
Membro desde: 09/25/14
207 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-2, Mcgee Fall 2014 Membro de USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Membros
Autoria de 6 guias
1Comentário do guia
dangerous? Really :) haha anyway nice review.
speedy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 2,976
