Ir para o conteúdo principal
DR.J Professional HI-04 Speaker Replacement
O que você precisa
  1. DR.J Professional HI-04 Speaker Replacement, Speaker: passo 1, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement, Speaker: passo 1, imagem 2 %32 DR.J Professional HI-04 Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Speaker Replacement: passo 2, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 2, imagem 2 %32 DR.J Professional HI-04 Speaker Replacement: passo 2, imagem 3 %32
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Speaker Replacement: passo 3, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 3, imagem 2 %32
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Speaker Replacement: passo 4, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Speaker Replacement: passo 5, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 5, imagem 2 %32 DR.J Professional HI-04 Speaker Replacement: passo 5, imagem 3 %32
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the speaker cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Speaker Replacement: passo 6, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Speaker Replacement: passo 7, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 7, imagem 2 %32
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Speaker Replacement: passo 8, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 8, imagem 2 %32
    • Slide the back panel with the speaker up from the bottom case of the project.
  9. DR.J Professional HI-04 Speaker Replacement: passo 9, imagem 1 %32 DR.J Professional HI-04 Speaker Replacement: passo 9, imagem 2 %32 DR.J Professional HI-04 Speaker Replacement: passo 9, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the two 10.0 mm screws that secure the speaker.
Conclusão
Baron Dutra
Membro desde: 11/01/23
825 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 83
