Ir para o conteúdo principal
DR.J Professional HI-04 Lens Replacement
O que você precisa
  1. DR.J Professional HI-04 Lens Replacement, Lens: passo 1, imagem 1 %32 DR.J Professional HI-04 Lens Replacement, Lens: passo 1, imagem 2 %32 DR.J Professional HI-04 Lens Replacement, Lens: passo 1, imagem 3 %32
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: passo 2, imagem 1 %32 DR.J Professional HI-04 Lens Replacement: passo 2, imagem 2 %32 DR.J Professional HI-04 Lens Replacement: passo 2, imagem 3 %32
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: passo 3, imagem 1 %32 DR.J Professional HI-04 Lens Replacement: passo 3, imagem 2 %32
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: passo 4, imagem 1 %32 DR.J Professional HI-04 Lens Replacement: passo 4, imagem 2 %32
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: passo 5, imagem 1 %32 DR.J Professional HI-04 Lens Replacement: passo 5, imagem 2 %32
    • Unscrew the cover of the lens.
Conclusão
Kory Lajoie
Membro desde: 11/01/23
127 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 44
Duração total: 266
