Ir para o conteúdo principal
DOSS SoundBox Speaker Replacement
O que você precisa
  1. DOSS SoundBox Speaker Replacement, Speaker: passo 1, imagem 1 %32 DOSS SoundBox Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
    Pergunte ao FixBot
    Comentar
  2. DOSS SoundBox Speaker Replacement: passo 2, imagem 1 %32 DOSS SoundBox Speaker Replacement: passo 2, imagem 2 %32
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
    Pergunte ao FixBot
    Comentar
  3. DOSS SoundBox Speaker Replacement: passo 3, imagem 1 %32 DOSS SoundBox Speaker Replacement: passo 3, imagem 2 %32
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow instructions in reverse order.
1Comentário do guia
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 50
Ao todo: 3,680
