Ir para o conteúdo principal
DOSS SoundBox Battery Replacement
O que você precisa
  1. DOSS SoundBox Battery Replacement, Battery: passo 1, imagem 1 %32 DOSS SoundBox Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
    Pergunte ao FixBot
    Comentar
  2. DOSS SoundBox Battery Replacement: passo 2, imagem 1 %32 DOSS SoundBox Battery Replacement: passo 2, imagem 2 %32
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. DOSS SoundBox Battery Replacement: passo 3, imagem 1 %32
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
    Pergunte ao FixBot
    Comentar
  4. DOSS SoundBox Battery Replacement: passo 4, imagem 1 %32
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
5Comentários do guia
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - Responder Compartilhar
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Philly newrocker - Responder Compartilhar
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Thousand Sunny - Responder Compartilhar
Link for Battery Replacement is broken.
Michael Scibetta - Responder Compartilhar
I believe this is the new link to replacement battery
Tenergy-37-2200-pcb
Fixer245 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 31
Últimos 30 dias: 143
Ao todo: 15,104
