Ir para o conteúdo principal
DOSS SoundBox Base-plate Replacement
O que você precisa
  1. DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, imagem 1 %32 DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, imagem 2 %32 DOSS SoundBox Base-plate Replacement, Base-plate: passo 1, imagem 3 %32
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
    Pergunte ao FixBot
    Comentar
  2. DOSS SoundBox Base-plate Replacement: passo 2, imagem 1 %32
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
    Pergunte ao FixBot
    Comentar
  3. DOSS SoundBox Base-plate Replacement: passo 3, imagem 1 %32
    • Lift the base-plate off of the enclosure.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 52
Ao todo: 2,647
