Ir para o conteúdo principal
DKnight MagicBox II Front Panel Assembly Replacement
O que você precisa
  1. DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: passo 1, imagem 1 %32 DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: passo 1, imagem 2 %32
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
    Pergunte ao FixBot
    Comentar
  2. DKnight MagicBox II Front Panel Assembly Replacement: passo 2, imagem 1 %32 DKnight MagicBox II Front Panel Assembly Replacement: passo 2, imagem 2 %32 DKnight MagicBox II Front Panel Assembly Replacement: passo 2, imagem 3 %32
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
    Pergunte ao FixBot
    Comentar
  3. DKnight MagicBox II Front Panel Assembly Replacement: passo 3, imagem 1 %32 DKnight MagicBox II Front Panel Assembly Replacement: passo 3, imagem 2 %32
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
    Pergunte ao FixBot
    Comentar
  4. DKnight MagicBox II Front Panel Assembly Replacement: passo 4, imagem 1 %32 DKnight MagicBox II Front Panel Assembly Replacement: passo 4, imagem 2 %32
    • Pull apart the two faces to separate the back panel from the front face plate.
    Pergunte ao FixBot
    Comentar
Conclusão
Anthony
Membro desde: 02/04/16
704 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-1, Blackwell Winter 2016 Membro de USF Tampa, Team 17-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G1
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 1,781
