Ir para o conteúdo principal
DJI Phantom 4 Advanced Remote Controller Back Panel Replacement
O que você precisa
    1. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      Pergunte ao FixBot
      Comentar
    2. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 2, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 2, imagem 2 %32
      • Remove three screws using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 3, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      Pergunte ao FixBot
      Comentar
    4. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 4, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 4, imagem 2 %32
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      Pergunte ao FixBot
      Comentar
    5. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 5, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: passo 5, imagem 2 %32
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Ao todo: 1,113
