Ir para o conteúdo principal
DJI Phantom 3 Advanced Motor Replacement
O que você precisa
  1. DJI Phantom 3 Advanced Motor Replacement, Battery: passo 1, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement, Battery: passo 1, imagem 2 %32
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Motor Replacement: passo 2, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 2, imagem 2 %32
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Motor Replacement, Cover: passo 3, imagem 1 %32
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Motor Replacement: passo 4, imagem 1 %32
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Motor Replacement: passo 5, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 5, imagem 2 %32
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Motor Replacement: passo 6, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 6, imagem 2 %32
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Motor Replacement: passo 7, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 7, imagem 2 %32 DJI Phantom 3 Advanced Motor Replacement: passo 7, imagem 3 %32
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Motor Replacement: passo 8, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 8, imagem 2 %32 DJI Phantom 3 Advanced Motor Replacement: passo 8, imagem 3 %32
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
  9. DJI Phantom 3 Advanced Motor Replacement, Motor: passo 9, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement, Motor: passo 9, imagem 2 %32 DJI Phantom 3 Advanced Motor Replacement, Motor: passo 9, imagem 3 %32
    • Turn the drone upside down with the motors facing the table.
    • Unscrew the four 5.5mm long 3mm screws directly under the motor using a 2.0mm hex bit screwdriver.
  10. DJI Phantom 3 Advanced Motor Replacement: passo 10, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 10, imagem 2 %32
    • Remove the glue that covers the three wires that connect the motor to the flight controller. Use a plastic opening tool or a metal tool if needed.
    • Repeat for each arm.
  11. DJI Phantom 3 Advanced Motor Replacement: passo 11, imagem 1 %32 DJI Phantom 3 Advanced Motor Replacement: passo 11, imagem 2 %32
    • Trace the black, yellow, and red wires from the motor to the flight controlle .
    • Desolder the three wires where they connect to the flight controller. Check out this desoldering guide to learn how to desolder: Desoldering Guide.
    • Take out the motor and repeat for the other motors if needed.
Conclusão
8 outras pessoas executaram este guia.
Tate Morell
Membro desde: 10/06/16
791 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-2, Livingston Fall 2016 Membro de Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Membros
Autoria de 12 guias
1Comentário do guia
Great teardown, clear instructions, thank you!
Kyle Michael - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 8,703
