Ir para o conteúdo principal
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
O que você precisa
Vídeo de Apresentação
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: passo 1, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: passo 1, imagem 2 %32
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: passo 2, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: passo 2, imagem 2 %32
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 1 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 2 %32 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: passo 3, imagem 3 %32
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
Conclusão
4 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
471.732 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.537 guias
3 comentários
hello do you still help with phantom drones
George Aguirre - Responder
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 4,654
