Ir para o conteúdo principal
DJI Mavic Pro Upper Shell Replacement
O que você precisa
    1. DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, imagem 1 %32 DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, imagem 2 %32 DJI Mavic Pro Upper Shell Replacement, Battery: passo 1, imagem 3 %32
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Pergunte ao FixBot
      Comentar
    1. DJI Mavic Pro Upper Shell Replacement, Upper Shell: passo 2, imagem 1 %32
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Pergunte ao FixBot
      Comentar
    2. DJI Mavic Pro Upper Shell Replacement: passo 3, imagem 1 %32
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Pergunte ao FixBot
      Comentar
    3. DJI Mavic Pro Upper Shell Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Pergunte ao FixBot
      Comentar
    4. DJI Mavic Pro Upper Shell Replacement: passo 5, imagem 1 %32
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Pergunte ao FixBot
      Comentar
    5. DJI Mavic Pro Upper Shell Replacement: passo 6, imagem 1 %32
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Pergunte ao FixBot
      Comentar
    6. DJI Mavic Pro Upper Shell Replacement: passo 7, imagem 1 %32
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S17-G3, White Fall 2018 Membro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membros
Autoria de 20 guias
2Comentários do guia
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Responder Compartilhar
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 78
Ao todo: 6,765
