Ir para o conteúdo principal
DJI Mavic Pro GPS Module Replacement
O que você precisa
    1. DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 1 %32 DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 2 %32 DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 3 %32
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Pergunte ao FixBot
      Comentar
    1. DJI Mavic Pro GPS Module Replacement, Upper Shell: passo 2, imagem 1 %32
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Pergunte ao FixBot
      Comentar
    2. DJI Mavic Pro GPS Module Replacement: passo 3, imagem 1 %32
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Pergunte ao FixBot
      Comentar
    3. DJI Mavic Pro GPS Module Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Pergunte ao FixBot
      Comentar
    4. DJI Mavic Pro GPS Module Replacement: passo 5, imagem 1 %32
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Pergunte ao FixBot
      Comentar
    5. DJI Mavic Pro GPS Module Replacement: passo 6, imagem 1 %32
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Pergunte ao FixBot
      Comentar
    6. DJI Mavic Pro GPS Module Replacement: passo 7, imagem 1 %32
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Pergunte ao FixBot
      Comentar
    1. DJI Mavic Pro GPS Module Replacement, GPS Module: passo 8, imagem 1 %32
      • Flip the upper shell over so the metallic plate is facing up.
      • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
      • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. DJI Mavic Pro GPS Module Replacement: passo 9, imagem 1 %32
      • Pry the metallic plate up from the upper shell by using a nylon spudger.
      • Remove the metallic plate from the upper shell by lifting the plate up and out.
      • You may hear a popping sound when prying the metallic plate, but no damage will occur.
      Pergunte ao FixBot
      Comentar
    3. DJI Mavic Pro GPS Module Replacement: passo 10, imagem 1 %32
      • Use tweezers to remove the GPS Module from the upper shell.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Kyle Kelser
Membro desde: 10/08/18
644 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G3, White Fall 2018 Membro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 83
Ao todo: 10,595
