Ir para o conteúdo principal
DDX/ Copperhead Hotend Installation
  1. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: passo 1, imagem 1 %32 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: passo 1, imagem 2 %32 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: passo 1, imagem 3 %32
    • Use 2x 2.5x6mm screws supplied with the Copperhead™ hotend.
    • Insert them in the mounting holes.
  2. DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: passo 2, imagem 1 %32 DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: passo 2, imagem 2 %32
    • Attach Adapter and hotend.
    • New lineNotice the orientation of the Adapter and Hot Block.
    • These indented marks should be oriented towards the front of the DDX.
    • The fixation screws that attach the DDX to the carriage plate will enter through them.
  3. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: passo 3, imagem 1 %32 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: passo 3, imagem 2 %32 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: passo 3, imagem 3 %32
    • Insert the Capricorn tube inside the Adapter and hotend.
    • Push hard until it hits the bottom.
    • Download the PTFE cutting fixture
  4. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: passo 4, imagem 1 %32 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: passo 4, imagem 2 %32 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: passo 4, imagem 3 %32
    • Insert the Capricorn tube in the cutting fixture
    • Drive it until it fits the Adapter
    • Pressing all together use the hobby knife to cut the tube straight.
    • At the end, the Capricorn should stand out about 5mm.
  5. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: passo 5, imagem 1 %32 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: passo 5, imagem 2 %32 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: passo 5, imagem 3 %32
    • Spread the housing apart from 2 to 3mm
    • Insert the Copperhead™ in at an angle.
    • Push it until the mounting holes align.
  6. DDX/ Copperhead Hotend Installation, Close DDX 1/2: passo 6, imagem 1 %32 DDX/ Copperhead Hotend Installation, Close DDX 1/2: passo 6, imagem 2 %32 DDX/ Copperhead Hotend Installation, Close DDX 1/2: passo 6, imagem 3 %32
    • If when clamping the DDX the gears collide:
    • Release the thumbscrew.
    • Open the hinge.
    • Clamp both halves while rotating the main gear back and forth.
  7. DDX/ Copperhead Hotend Installation, Close DDX 2/2: passo 7, imagem 1 %32 DDX/ Copperhead Hotend Installation, Close DDX 2/2: passo 7, imagem 2 %32 DDX/ Copperhead Hotend Installation, Close DDX 2/2: passo 7, imagem 3 %32
    • When the DDX closes down verify the mounting holes alignment.
    • Screw the back screws to close it.
Conclusão
Tiny Machines 3D
Membro desde: 11/16/19
3.019 Reputação
Autoria de 14 guias
Equipe
Tiny Machines 3D Membro de Tiny Machines 3D
Community
5 Membros
Autoria de 41 guias
2Comentários do guia
where do i get the cutting fixture
Sarbartha Sengupta - Responder
Thanks for your questions. We’ve added a link to step 3.
Tiny Machines 3D -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 243
