Ir para o conteúdo principal
D-Link EBR-2310 LED Light Replacement
O que você precisa
    1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: passo 1, imagem 1 %32
      • Begin by placing the wired router face down.
      • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
      • The two bottom plastic screw coverings do not need to be taken off.
      Pergunte ao FixBot
      Comentar
    2. D-Link EBR-2310 LED Light Replacement, Remove Screws: passo 2, imagem 1 %32
      • Using a Phillips #2 screwdriver, remove the two top screws.
      Pergunte ao FixBot
      Comentar
    3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: passo 3, imagem 1 %32
      • Use a plastic opening tool between the edges of the router and gently pry the device apart.
      • Release the clips as you work your way around the device to avoid breaking them.
      • Separate the front and back case of the router.
      Pergunte ao FixBot
      Comentar
    4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: passo 4, imagem 1 %32 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: passo 4, imagem 2 %32
      • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
      • It should easily snap out of place.
      Pergunte ao FixBot
      Comentar
    5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: passo 5, imagem 1 %32 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: passo 5, imagem 2 %32
      • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
      Pergunte ao FixBot
      Comentar
    6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: passo 6, imagem 1 %32
      • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
      • You have now removed the logic board from your device.
      Pergunte ao FixBot
      Comentar
    1. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: passo 7, imagem 1 %32
      • Locate the problematic LED light on the motherboard.
      • Using a plastic opening tool, very gently tilt its black base backwards.
      Pergunte ao FixBot
      Comentar
    2. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: passo 8, imagem 1 %32 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: passo 8, imagem 2 %32
      • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
      Pergunte ao FixBot
      Comentar
    3. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: passo 9, imagem 1 %32
      Ferramenta utilizada neste passo:
      • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
      Pergunte ao FixBot
      Comentar
    4. D-Link EBR-2310 LED Light Replacement, Complete Removal: passo 10, imagem 1 %32
      • You should now have a removed LED light, ready to be replaced with a new one.
      Pergunte ao FixBot
      Comentar
Conclusão
Jessica
Membro desde: 09/19/14
428 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 716
