Ir para o conteúdo principal
D-Link DIR-890L Reset Button Replacement
O que você precisa
  1. D-Link DIR-890L Reset Button Replacement, Motherboard: passo 1, imagem 1 %32
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  2. D-Link DIR-890L Reset Button Replacement: passo 2, imagem 1 %32 D-Link DIR-890L Reset Button Replacement: passo 2, imagem 2 %32 D-Link DIR-890L Reset Button Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
  3. D-Link DIR-890L Reset Button Replacement: passo 3, imagem 1 %32 D-Link DIR-890L Reset Button Replacement: passo 3, imagem 2 %32
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  4. D-Link DIR-890L Reset Button Replacement: passo 4, imagem 1 %32 D-Link DIR-890L Reset Button Replacement: passo 4, imagem 2 %32 D-Link DIR-890L Reset Button Replacement: passo 4, imagem 3 %32
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  5. D-Link DIR-890L Reset Button Replacement: passo 5, imagem 1 %32 D-Link DIR-890L Reset Button Replacement: passo 5, imagem 2 %32 D-Link DIR-890L Reset Button Replacement: passo 5, imagem 3 %32
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  6. D-Link DIR-890L Reset Button Replacement: passo 6, imagem 1 %32 D-Link DIR-890L Reset Button Replacement: passo 6, imagem 2 %32
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  7. D-Link DIR-890L Reset Button Replacement, Reset Button: passo 7, imagem 1 %32 D-Link DIR-890L Reset Button Replacement, Reset Button: passo 7, imagem 2 %32 D-Link DIR-890L Reset Button Replacement, Reset Button: passo 7, imagem 3 %32
    • Locate the reset switch at the top of the motherboard.
    • Flip the motherboard over.
    • Locate the reset switch's 4 solder joints on the underside of the motherboard.
  8. D-Link DIR-890L Reset Button Replacement: passo 8, imagem 1 %32
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the reset switch from the board.
    • For more information, see this guide on desoldering.
Conclusão
Rachel Shaw
Membro desde: 10/06/16
553 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-7, Livingston Fall 2016 Membro de Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,128
