Introdução
The power switch is the black button on the back of the router. If it is not pressing and appears to be broken, this guide will walk you through on the replacement of this switch.
O que você precisa
Orient the router so the narrow end of the router faces you and the ports face away from you.
The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
Pry off the antenna connectors using a heavy-duty spudger.
Locate the power switch on the top left of the motherboard.
Turn the motherboard upside down.
Locate the 6 solder joints that connect the power switch to the motherboard. They are arranged in 2 columns of 3.
Using a soldering iron and desoldering pump, desolder the power switch from the board.
