Ir para o conteúdo principal
D-Link DIR-890L Power Adapter Port Replacement
O que você precisa
  1. D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, imagem 3 %32
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Adapter Port Replacement: passo 2, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 2, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 2, imagem 3 %32
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Adapter Port Replacement: passo 3, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 3, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 3, imagem 3 %32
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Adapter Port Replacement, Motherboard: passo 4, imagem 1 %32
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Adapter Port Replacement: passo 5, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 5, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Spudger
  6. D-Link DIR-890L Power Adapter Port Replacement: passo 6, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 6, imagem 2 %32
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Adapter Port Replacement: passo 7, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 7, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 7, imagem 3 %32
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Adapter Port Replacement: passo 8, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 8, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 8, imagem 3 %32
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Adapter Port Replacement: passo 9, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 9, imagem 2 %32
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, imagem 3 %32
    • Locate the power adapter port at the top left of the motherboard.
    • Flip the motherboard over.
    • Locate the 3 solder joints that connect the power adapter port to the motherboard.
  11. D-Link DIR-890L Power Adapter Port Replacement: passo 11, imagem 1 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 11, imagem 2 %32 D-Link DIR-890L Power Adapter Port Replacement: passo 11, imagem 3 %32
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the power adapter port from the board.
    • For more information, see this guide on desoldering
Conclusão
Uma outra pessoa concluiu este guia.
Rachel Shaw
Membro desde: 10/06/16
553 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-7, Livingston Fall 2016 Membro de Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Membros
Autoria de 12 guias
1Comentário do guia
What are the specifications of the power port if we would like to replace it?
Chad Altobelli - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 791
