Introdução
The LED backlight may burn out, causing the backlight to cease working properly. This guide will demonstrate how to replace the LED backlight.
O que você precisa
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the metal backing located directly underneath the white plastic casing.
