Ir para o conteúdo principal
Curtain Rod Bracket Replacement
O que você precisa
  1. Curtain Rod Bracket Replacement, Bracket: passo 1, imagem 1 %32 Curtain Rod Bracket Replacement, Bracket: passo 1, imagem 2 %32
    • If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
  2. Curtain Rod Bracket Replacement: passo 2, imagem 1 %32 Curtain Rod Bracket Replacement: passo 2, imagem 2 %32
    • Observe the hole of the screw(s) that was ripped out of the wall.
    • Determine whether the plastic anchor will fit in the current size of the hole.
    • If the hole is smaller than the anchor, continue to Step 3. If the hole is bigger, complete this guide on patching a hole in dry wall.
  3. Curtain Rod Bracket Replacement: passo 3, imagem 1 %32 Curtain Rod Bracket Replacement: passo 3, imagem 2 %32
    • Use a ¼ inch drill bit to drill the hole(s) that the anchor will be placed into. Drill into the wall and continue drilling as you pull out of the wall.
    • Avoid placing hands near the drill bit while in use. If you have medium to long-length hair, tie your hair back to avoid possible injury.
  4. Curtain Rod Bracket Replacement: passo 4, imagem 1 %32 Curtain Rod Bracket Replacement: passo 4, imagem 2 %32 Curtain Rod Bracket Replacement: passo 4, imagem 3 %32
    • Hammer the hollow wall anchor(s) into the hole until flush with the drywall.
  5. Curtain Rod Bracket Replacement: passo 5, imagem 1 %32
    • Paint the wall anchor and any surrounding area that has been damaged so that it matches the wall.
  6. Curtain Rod Bracket Replacement: passo 6, imagem 1 %32 Curtain Rod Bracket Replacement: passo 6, imagem 2 %32
    • Screw the bracket into the anchor(s) with a screwdriver. The bracket will be secured to the wall.
  7. Curtain Rod Bracket Replacement: passo 7, imagem 1 %32 Curtain Rod Bracket Replacement: passo 7, imagem 2 %32
    • Touch up with paint if necessary.
  8. Curtain Rod Bracket Replacement: passo 8, imagem 1 %32 Curtain Rod Bracket Replacement: passo 8, imagem 2 %32
    • Rehang your curtain rod and curtains by placing the rod onto the bracket.
Conclusão
Enjoy your renewed privacy!
Ashtyn Drake
Membro desde: 10/14/22
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 919
