Ir para o conteúdo principal
Cuisinart Griddler GR- 4N Button Spring Replacement
O que você precisa
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: passo 1, imagem 1 %32 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: passo 1, imagem 2 %32
      • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
      • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
      Pergunte ao FixBot
      Comentar
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 2, imagem 1 %32
      • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
      Pergunte ao FixBot
      Comentar
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 3, imagem 1 %32
      • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
      Pergunte ao FixBot
      Comentar
    4. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 4, imagem 1 %32
      • Remove the single 5.5 mm Phillips #2 screw next to center black button.
      • After removing the center screw the metal plate should be free to remove.
      Pergunte ao FixBot
      Comentar
    5. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 5, imagem 1 %32 Cuisinart Griddler GR- 4N Button Spring Replacement: passo 5, imagem 2 %32
      • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
      • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
      • The aligned parts will allow the cooking surfaces to work properly.
      Pergunte ao FixBot
      Comentar
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: passo 6, imagem 1 %32
      • Depress one of the gray tabs on the side of the housing.
      Pergunte ao FixBot
      Comentar
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 7, imagem 1 %32
      • Pull out the black button and the spring will also come out within it.
      Pergunte ao FixBot
      Comentar
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 8, imagem 1 %32
      • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Laine Aro
Membro desde: 04/11/16
173 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-12, Maness Spring 2016 Membro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 4,668
