Introdução
The safety switch keeps the food processor's blades from accidentally spinning while the device is on. A broken safety feature is potentially harmful. Removing and replacing this component requires soldering. Check out this soldering guide for instructions.
O que você precisa
Turn the food processor's base upside down by lifting it up and turning it over.
Position the base so that the on and pulse buttons are facing you.
Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
Orient the device so that the power cord is facing you.
Remove the two 10.0mm screws that hold down the safety switch with a Phillips #2 screwdriver.
Pull up on the safety switch with your hands to lift it out of the casing.
Uma outra pessoa concluiu este guia.
4 comentários
Clear, precise instructions and great pics. This isn’t a difficult fix at all though, I would say it’s about a 4. The only reason I say that, is when people see a DIY labeled difficult, they tend to think it’s over their head, when many times it isn’t. One thing I would have like to see is what each of those wires do, because knowing that would ensure I don’t attach the wrong wire to the wrong part of the switch; or, like what I did, is drop the safety switch, and have all the little pieces come out of the plastic container.
Where to buy replacement safety switch.
What is the white wire for on the safety switch. It seems the safety switch connects the brown and orange wire when activated, but sends the power to the white wire when not activated by installing the top that pushes the white pin down to turn on the switch. So when plugged in, the white wire is hot, like with power, and when the top is turned to lock on, the white wire is deactivated.????????
Mac
My 2014 Cuisinart food processor (model FP-12MR) recently stopped spinning. The safety switch was not broken.
At any rate, I fixed it by depressing the safety switch on the front of the base unit and then jamming a toothpick in between the top of the depressed safety switch and the safety switch slot. Then I just broke off the toothpick that was left sticking out. This had the effect of permanently pinning the safety switch in the ON position.
NOTE: there is no disassembly required. The safety switch that I'm talking about is located on the base of the machine. It is on the front and is one of the recessed lock downs that locks the bowl in place when you rotate the bowl (counter clockwise). If you look into that recessed lock down you will see the switch. The way it is supposed to work is, when the bowl is locked in place and the lid is fastened down a small tab comes out of the base of the handle bowl handle and pushes the safety switch in.
