Ir para o conteúdo principal
Cuisinart DCC-1100 Drip Spring Replacement
O que você precisa
    1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: passo 1, imagem 1 %32
      • Unplug the coffee maker.
      Pergunte ao FixBot
      Comentar
    2. Cuisinart DCC-1100 Drip Spring Replacement: passo 2, imagem 1 %32
      • Remove the coffee pot and open the top lid.
      Pergunte ao FixBot
      Comentar
    3. Cuisinart DCC-1100 Drip Spring Replacement: passo 3, imagem 1 %32 Cuisinart DCC-1100 Drip Spring Replacement: passo 3, imagem 2 %32
      • Remove the basket filter holder.
      Pergunte ao FixBot
      Comentar
    4. Cuisinart DCC-1100 Drip Spring Replacement: passo 4, imagem 1 %32
      • Remove the basket filter from the holder.
      Pergunte ao FixBot
      Comentar
    5. Cuisinart DCC-1100 Drip Spring Replacement: passo 5, imagem 1 %32
      • Press up on the drip spring mechanism.
      Pergunte ao FixBot
      Comentar
    6. Cuisinart DCC-1100 Drip Spring Replacement: passo 6, imagem 1 %32 Cuisinart DCC-1100 Drip Spring Replacement: passo 6, imagem 2 %32
      • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
      Pergunte ao FixBot
      Comentar
    7. Cuisinart DCC-1100 Drip Spring Replacement: passo 7, imagem 1 %32
      • Remove the spring from the dripper.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Josh Harvey
Membro desde: 01/25/18
910 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S20-G4, Passmore Spring 2018 Membro de USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Membros
Autoria de 27 guias
4Comentários do guia
Where do you find replacement springs?
Mrich - Responder Compartilhar
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett - Responder Compartilhar
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Responder Compartilhar
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 83
Ao todo: 14,002
