Ir para o conteúdo principal
CrystalView NB4-35788 Battery Replacement
O que você precisa
  1. CrystalView NB4-35788 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: passo 2, imagem 1 %32
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: passo 3, imagem 1 %32
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: passo 5, imagem 1 %32 CrystalView NB4-35788 Battery Replacement: passo 5, imagem 2 %32
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Conclusão
Courtney Clark
Membro desde: 01/12/17
218 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 294
