Ir para o conteúdo principal
Crosley CR704 Speaker Replacement
O que você precisa
  1. Crosley CR704 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: passo 2, imagem 1 %32
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: passo 3, imagem 1 %32
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: passo 4, imagem 1 %32
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
Conclusão
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Uma outra pessoa concluiu este guia.
MarkAnthony
Membro desde: 09/22/13
772 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
Membros da 3
Autoria de 5 guias
Um comentário
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 3,059
