Ir para o conteúdo principal
Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
O que você precisa
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: passo 1, imagem 1 %32
      • Remove the power cord from the wall outlet first, disconnecting power from the device.
      Pergunte ao FixBot
      Comentar
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 2, imagem 1 %32
      • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
      Pergunte ao FixBot
      Comentar
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 3, imagem 1 %32 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 3, imagem 2 %32
      • Grasp the power cord input connector firmly with forefinger and thumb.
      • Without tugging, apply pulling force until the connector is free from device
      Pergunte ao FixBot
      Comentar
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: passo 4, imagem 1 %32 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: passo 4, imagem 2 %32 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: passo 4, imagem 3 %32
      • Orient the crock pot where the lid locked and unlocked icons are visible.
      • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
      • Remove the lid.
      Pergunte ao FixBot
      Comentar
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: passo 5, imagem 1 %32
      • Remove the inner pot and set it aside for reassembly.
      Pergunte ao FixBot
      Comentar
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 6, imagem 1 %32
      • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
      • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 7, imagem 1 %32
      • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
      Pergunte ao FixBot
      Comentar
    4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 8, imagem 1 %32 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 8, imagem 2 %32
      • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
      Pergunte ao FixBot
      Comentar
    5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 9, imagem 1 %32
      • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 10, imagem 1 %32
      • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
      • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
      Pergunte ao FixBot
      Comentar
    7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 11, imagem 1 %32
      • Reorient the crockpot on its side to prepare for the heating element removal.
      Pergunte ao FixBot
      Comentar
    8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 12, imagem 1 %32
      • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
      Pergunte ao FixBot
      Comentar
    9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 13, imagem 1 %32 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: passo 13, imagem 2 %32
      • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
      • Carefully remove the heating element from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
where do you get a heating element?
Stephanie Brown - Responder Compartilhar
Ma machine j'ai acheté neuf et elle s'allume pas
MOHAMED DJA YAHIA - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 6,094
