Ir para o conteúdo principal
Cricut Maker 3 Blade Replacement
  1. Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: passo 1, imagem 1 %32 Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: passo 1, imagem 2 %32 Cricut Maker 3 Blade Replacement, Prepare your Cricut for disassembly: passo 1, imagem 3 %32
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
  2. Cricut Maker 3 Blade Replacement, Open the Cricut: passo 2, imagem 1 %32 Cricut Maker 3 Blade Replacement, Open the Cricut: passo 2, imagem 2 %32
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
  3. Cricut Maker 3 Blade Replacement, Open the clamp: passo 3, imagem 1 %32 Cricut Maker 3 Blade Replacement, Open the clamp: passo 3, imagem 2 %32
    • Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
  4. Cricut Maker 3 Blade Replacement: passo 4, imagem 1 %32 Cricut Maker 3 Blade Replacement: passo 4, imagem 2 %32
    • While holding the blade housing in the tool holder, fully open clamp B by pulling the plastic latch to the right.
  5. Cricut Maker 3 Blade Replacement, Remove the blade housing: passo 5, imagem 1 %32 Cricut Maker 3 Blade Replacement, Remove the blade housing: passo 5, imagem 2 %32
    • Grab the blade housing by the top and remove it from the tool holder.
  6. Cricut Maker 3 Blade Replacement, Remove the blade: passo 6, imagem 1 %32 Cricut Maker 3 Blade Replacement, Remove the blade: passo 6, imagem 2 %32
    • Be careful not to cut yourself while working near the small, sharp blade.
    • Hold the blade housing between your index finger and middle finger with the blade pointed away from your palm.
    • Use your thumb to press the plunger to push the blade out of the housing.
  7. Cricut Maker 3 Blade Replacement: passo 7, imagem 1 %32 Cricut Maker 3 Blade Replacement: passo 7, imagem 2 %32
    • Firmly grip the flat sides of the blade to avoid cutting yourself.
    • With the plunger still pressed, use your free hand to carefully grip the blade and pull it out of the housing to remove it.
    • The blade is held in with a magnet and should come out of the housing easily.
Conclusão
Spencer Pennington
Membro desde: 09/09/23
16.989 Reputação
Autoria de 113 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.449 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 67
