Ir para o conteúdo principal
Cricut Maker 3 Blade Housing Replacement
  1. Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: passo 1, imagem 1 %32 Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: passo 1, imagem 2 %32 Cricut Maker 3 Blade Housing Replacement, Prepare your Cricut for disassembly: passo 1, imagem 3 %32
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
  2. Cricut Maker 3 Blade Housing Replacement, Open the Cricut: passo 2, imagem 1 %32 Cricut Maker 3 Blade Housing Replacement, Open the Cricut: passo 2, imagem 2 %32
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
  3. Cricut Maker 3 Blade Housing Replacement, Open the clamp: passo 3, imagem 1 %32 Cricut Maker 3 Blade Housing Replacement, Open the clamp: passo 3, imagem 2 %32
    • Partially open clamp B on the tool holder by pulling the plastic latch away from the tool holder.
  4. Cricut Maker 3 Blade Housing Replacement: passo 4, imagem 1 %32 Cricut Maker 3 Blade Housing Replacement: passo 4, imagem 2 %32
    • While holding the blade housing in the tool holder, fully open clamp B by pulling the plastic latch to the right.
  5. Cricut Maker 3 Blade Housing Replacement, Remove the blade housing: passo 5, imagem 1 %32 Cricut Maker 3 Blade Housing Replacement, Remove the blade housing: passo 5, imagem 2 %32
    • Grab the blade housing by the top and remove it from the tool holder.
Conclusão
Spencer Pennington
Membro desde: 09/09/23
17.049 Reputação
Autoria de 113 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.455 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 101
