Ir para o conteúdo principal
Creative Ziio 7" Motherboard Replacement
O que você precisa
    1. Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Pergunte ao FixBot
      Comentar
    1. Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, imagem 1 %32 Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, imagem 2 %32 Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, imagem 3 %32
      • Remove the copper plate covering the motherboard by desoldering the ten solder points.
      • The solder point in the bottom right corner is marked but hidden by the soldering iron.
      Pergunte ao FixBot
      Comentar
    2. Creative Ziio 7" Motherboard Replacement: passo 3, imagem 1 %32 Creative Ziio 7" Motherboard Replacement: passo 3, imagem 2 %32
      • Remove the adhesive tape covering the three wires connected to the motherboard.
      • Desolder the solder points connecting the wires to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Creative Ziio 7" Motherboard Replacement: passo 4, imagem 1 %32 Creative Ziio 7" Motherboard Replacement: passo 4, imagem 2 %32 Creative Ziio 7" Motherboard Replacement: passo 4, imagem 3 %32
      • Disconnect the ribbon cable that is attached underneath the copper plate.
      • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Creative Ziio 7" Motherboard Replacement: passo 5, imagem 1 %32 Creative Ziio 7" Motherboard Replacement: passo 5, imagem 2 %32
      • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
      • The copper plate will be removed by now. However, the picture does not show this.
      Pergunte ao FixBot
      Comentar
    5. Creative Ziio 7" Motherboard Replacement: passo 6, imagem 1 %32 Creative Ziio 7" Motherboard Replacement: passo 6, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Lift up the motherboard.
      • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
      • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
      Pergunte ao FixBot
      Comentar
    6. Creative Ziio 7" Motherboard Replacement: passo 7, imagem 1 %32
      • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
      • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
      Pergunte ao FixBot
      Comentar
    7. Creative Ziio 7" Motherboard Replacement: passo 8, imagem 1 %32
      • Remove the old motherboard and dispose of it resposibly.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 14-10, Maness Spring 2013 Membro de Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 25
Ao todo: 1,461
