Ir para o conteúdo principal
Creative Ziio 7" LCD Screen Replacement
O que você precisa
    1. Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, imagem 1 %32 Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, imagem 2 %32 Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Pergunte ao FixBot
      Comentar
    1. Creative Ziio 7" LCD Screen Replacement, LCD Screen: passo 2, imagem 1 %32
      • Remove the four 3mm Philips #00 screws around the large silver battery.
      Pergunte ao FixBot
      Comentar
    2. Creative Ziio 7" LCD Screen Replacement: passo 3, imagem 1 %32
      • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
      Pergunte ao FixBot
      Comentar
    3. Creative Ziio 7" LCD Screen Replacement: passo 4, imagem 1 %32 Creative Ziio 7" LCD Screen Replacement: passo 4, imagem 2 %32 Creative Ziio 7" LCD Screen Replacement: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
      • Carefully lift up the circuit board on the detached side.
      • There is another ribbon cable attached to the underside of the circuit board.
      • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
      • The circuit board is extremely delicate. Move carefully and don't rush on this step!
      Pergunte ao FixBot
      Comentar
    4. Creative Ziio 7" LCD Screen Replacement: passo 5, imagem 1 %32
      • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
      Pergunte ao FixBot
      Comentar
    5. Creative Ziio 7" LCD Screen Replacement: passo 6, imagem 1 %32
      • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
      • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
      Pergunte ao FixBot
      Comentar
    6. Creative Ziio 7" LCD Screen Replacement: passo 7, imagem 1 %32 Creative Ziio 7" LCD Screen Replacement: passo 7, imagem 2 %32
      • Carefully pry the thin, metal frame from around the LCD screen.
      • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
      Pergunte ao FixBot
      Comentar
    7. Creative Ziio 7" LCD Screen Replacement: passo 8, imagem 1 %32
      • Carefully remove the black LCD screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Kyle
Membro desde: 04/16/13
126 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-10, Maness Spring 2013 Membro de Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membros
Autoria de 15 guias
2Comentários do guia
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Responder Compartilhar
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 1,782
