Ir para o conteúdo principal
Creative Ziio 7" Camera Replacement
O que você precisa
    1. Creative Ziio 7" Camera Replacement, Back Panel: passo 1, imagem 1 %32 Creative Ziio 7" Camera Replacement, Back Panel: passo 1, imagem 2 %32 Creative Ziio 7" Camera Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Pergunte ao FixBot
      Comentar
    1. Creative Ziio 7" Camera Replacement, Camera: passo 2, imagem 1 %32 Creative Ziio 7" Camera Replacement, Camera: passo 2, imagem 2 %32 Creative Ziio 7" Camera Replacement, Camera: passo 2, imagem 3 %32
      • Unscrew the four 3mm Phillips #00 screws found in each corner of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Creative Ziio 7" Camera Replacement: passo 3, imagem 1 %32 Creative Ziio 7" Camera Replacement: passo 3, imagem 2 %32 Creative Ziio 7" Camera Replacement: passo 3, imagem 3 %32
      • Unplug the ribbon cable near the edge of the motherboard in the bottom right of the device.
      Pergunte ao FixBot
      Comentar
    3. Creative Ziio 7" Camera Replacement: passo 4, imagem 1 %32 Creative Ziio 7" Camera Replacement: passo 4, imagem 2 %32
      • Lift up the motherboard.
      • A mesh-like strip on the right side will be connected to the bottom of the motherboard.
      • Remove the tape on top of the strip. Use tweezers or pliers to pull on the strip and unplug it.
      Pergunte ao FixBot
      Comentar
    4. Creative Ziio 7" Camera Replacement: passo 5, imagem 1 %32 Creative Ziio 7" Camera Replacement: passo 5, imagem 2 %32
      • Lift up the motherboard and locate the ribbon cable (burnt orange-colored strip) centered on top of the motherboard.
      • The ribbon cable with the attached camera is plugged into the motherboard.
      • Unplug the ribbon cable using your fingers to pull up on the flap.
      Pergunte ao FixBot
      Comentar
    5. Creative Ziio 7" Camera Replacement: passo 6, imagem 1 %32 Creative Ziio 7" Camera Replacement: passo 6, imagem 2 %32
      • Use a spudger to pry the camera away from the rubber camera mount.
      • Do not remove the entire rubber camera mount. Only remove the camera attached with adhesive.
      • Remove the broken camera and use electronic-friendly adhesive to attach a new camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 14-10, Maness Spring 2013 Membro de Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 759
