Ir para o conteúdo principal
Creative Ziio 7" Battery Replacement
O que você precisa
    1. Creative Ziio 7" Battery Replacement, Back Panel: passo 1, imagem 1 %32 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, imagem 2 %32 Creative Ziio 7" Battery Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Pergunte ao FixBot
      Comentar
    1. Creative Ziio 7" Battery Replacement, Battery: passo 2, imagem 1 %32 Creative Ziio 7" Battery Replacement, Battery: passo 2, imagem 2 %32 Creative Ziio 7" Battery Replacement, Battery: passo 2, imagem 3 %32
      • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
      • The last point is hidden by the soldering iron.
      • Remove the copper plate once all the solder points are undone.
      Pergunte ao FixBot
      Comentar
    2. Creative Ziio 7" Battery Replacement: passo 3, imagem 1 %32 Creative Ziio 7" Battery Replacement: passo 3, imagem 2 %32
      • Remove adhesive tape covering the three wires connected to the motherboard.
      • Desolder the solder points connecting the wires to the mother board.
      Pergunte ao FixBot
      Comentar
    3. Creative Ziio 7" Battery Replacement: passo 4, imagem 1 %32 Creative Ziio 7" Battery Replacement: passo 4, imagem 2 %32
      • With a spudger, pry the battery from the back of the LCD screen.
      • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
      Pergunte ao FixBot
      Comentar
    4. Creative Ziio 7" Battery Replacement: passo 5, imagem 1 %32
      • Remove old battery and dispose of it responsibly.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Bryce Simmons
Membro desde: 04/16/13
150 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-10, Maness Spring 2013 Membro de Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 1,302
