Ir para o conteúdo principal
Creative Zen Vision W Keypad Replacement
O que você precisa
  1. Creative Zen Vision W Keypad Replacement, Front Cover: passo 1, imagem 1 %32 Creative Zen Vision W Keypad Replacement, Front Cover: passo 1, imagem 2 %32
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Creative Zen Vision W Keypad Replacement: passo 2, imagem 1 %32 Creative Zen Vision W Keypad Replacement: passo 2, imagem 2 %32 Creative Zen Vision W Keypad Replacement: passo 2, imagem 3 %32
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
    Pergunte ao FixBot
    Comentar
  3. Creative Zen Vision W Keypad Replacement, LCD Screen: passo 3, imagem 1 %32 Creative Zen Vision W Keypad Replacement, LCD Screen: passo 3, imagem 2 %32 Creative Zen Vision W Keypad Replacement, LCD Screen: passo 3, imagem 3 %32
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
    Pergunte ao FixBot
    Comentar
  4. Creative Zen Vision W Keypad Replacement: passo 4, imagem 1 %32
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
    Pergunte ao FixBot
    Comentar
  5. Creative Zen Vision W Keypad Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
    Pergunte ao FixBot
    Comentar
  6. Creative Zen Vision W Keypad Replacement: passo 6, imagem 1 %32 Creative Zen Vision W Keypad Replacement: passo 6, imagem 2 %32 Creative Zen Vision W Keypad Replacement: passo 6, imagem 3 %32
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
    Pergunte ao FixBot
    Comentar
  7. Creative Zen Vision W Keypad Replacement, Keypad: passo 7, imagem 1 %32
    • Peel the orange sticker off of the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Creative Zen Vision W Keypad Replacement: passo 8, imagem 1 %32 Creative Zen Vision W Keypad Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
    Pergunte ao FixBot
    Comentar
  9. Creative Zen Vision W Keypad Replacement: passo 9, imagem 1 %32 Creative Zen Vision W Keypad Replacement: passo 9, imagem 2 %32
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
    Pergunte ao FixBot
    Comentar
Conclusão
Tim Wilson
Membro desde: 04/11/13
143 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-2, Regan Spring 2013 Membro de Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 744
