Ir para o conteúdo principal
Creative Zen V Plus Headphone Jack Replacement
O que você precisa
  1. Creative Zen V Plus Headphone Jack Replacement, Prerequisite Only: passo 1, imagem 1 %32
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Headphone Jack Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Headphone Jack Replacement: passo 3, imagem 1 %32
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Headphone Jack Replacement: passo 4, imagem 1 %32 Creative Zen V Plus Headphone Jack Replacement: passo 4, imagem 2 %32
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Headphone Jack Replacement: passo 5, imagem 1 %32
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Headphone Jack Replacement: passo 6, imagem 1 %32 Creative Zen V Plus Headphone Jack Replacement: passo 6, imagem 2 %32 Creative Zen V Plus Headphone Jack Replacement: passo 6, imagem 3 %32
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Headphone Jack Replacement, Headphone Jack: passo 7, imagem 1 %32
    • Locate the circles of metal holding the headphone jack to the logic board. Using a soldering iron, de-solder these circles and remove the headphone jack.
Conclusão
Joshua Meines
Membro desde: 10/19/16
316 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-5, Baechle Fall 2016 Membro de IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 418
