Ir para o conteúdo principal
Creative Nomad Jukebox Zen Battery Replacement
O que você precisa
  1. Creative Nomad Jukebox Zen Battery Replacement, Battery: passo 1, imagem 1 %32 Creative Nomad Jukebox Zen Battery Replacement, Battery: passo 1, imagem 2 %32 Creative Nomad Jukebox Zen Battery Replacement, Battery: passo 1, imagem 3 %32
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Battery Replacement: passo 2, imagem 1 %32 Creative Nomad Jukebox Zen Battery Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to open top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Battery Replacement: passo 3, imagem 1 %32
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover.
  4. Creative Nomad Jukebox Zen Battery Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to unclip the metal bracket holding the battery down.
    • When sticker is torn warranty is void.
  5. Creative Nomad Jukebox Zen Battery Replacement: passo 5, imagem 1 %32 Creative Nomad Jukebox Zen Battery Replacement: passo 5, imagem 2 %32
    • Desolder both red and black wires coming from battery.
    • Como soldar e dessoldar contatos Use soldering gun with care as it becomes extremely hot and can cause burns.
    • Make sure to solder the black and red wires back into the same locations.
Conclusão
Eli Richter
Membro desde: 03/08/17
301 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S4-G5, Baechle Spring 2017 Membro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 1,368
